Thread: New Mill losing steps
02-11-2014 #9
Are you sure it's loosing steps or just not moving the correct amount.? Those numbers for X & Y suggest 2.5mm pitch running 2000 micro steps which would work out 800 Steps per and your not set to that amount so would be some error.?
Similair with Z axis and working on same pitch but with 1000 micro step = 400 steps per again your not quite there.!
Need lot more info to help correctly with setup and what can achieve.
Voltage the drivers are using. (also make and model of drives)
Micro stepping set on drives.
Ballscrew or Lead screw and the pitch. Ie distance traveled for one Revolution.
Units set in Mach Ie: MM or inch
What size motors and frame size Ie Nema 23 or 34.? They look like 34's.!
I see a Laptop in back ground are you using this to run machine via parallel port.?
Give this info and we can help better thou you should be getting much more than you are now without loosing steps.Last edited by JAZZCNC; 02-11-2014 at 11:38 PM.
Router losing steps. Solution needed. Will this help?
By cncbobuk in forum Chinese MachinesReplies: 9Last Post: 27-12-2017, 03:40 AM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Heelp! Dual axis steppers.. Losing steps.. Pulling hair out..!
By fasteddy in forum Motor Drivers & ControllersReplies: 9Last Post: 14-05-2010, 02:32 PM
