    It's a boob size lol
    To go through something sim to this
    Am I the only one who doesn't know? What is a double D?
    No
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    EDM would be expensive if you were paying someone else to do it, however if you've got time and are willing to build a machine, then it wouldn't be quite so bad, but it depends on what your goals are.
    Another option could be to machine the shape as near as possible on a mill, then use a small shaper and custom cutter to cut the sharp corners.
    Dealing with Ti isn't that much different from stainless. You've got to use sharp tools and ensure they never rub as it'll workharden in the blink of an eye. It also produces swarf with a far shaper edge than stainless, so you have to be careful handling it.
    No once again, the first thing it reminded me of was Double Diamond ale I could sup a few of those at one time.
  5. #15
    Cheers for the info but EDM is out of my league, think I will drill the corners and see how it looks. This is the easiest option I think, failing that machine to has close has pos like you say and then shunt be to hard to make a broach just to take the corners out, should be able to use a small press then.
    Failing both these options I would have see about getting them done else where, just wanted to make these with paying anybody to do any machine work.
    Mill as close as you can then finish with a custom made profile tool in a shaper, press or even using a mill quill action with the rotation locked.
  7. #17
    Yep that's what I was and advised and thought about, maybe just easier and quicker to have them broach. Thinking about it it may cause issues using a 4mm end mill to cut titanium, maybe just easier to drill 8mm or so and then just send to be done. Just depends on the cost for doing 100 at a time, will see how the over cut looks first but then still left with the dilemma of the 4mm cutter. Alloy would be no probs and some would be done in alloy, cheers for all your inputs.
  8. #18
    Hi Dean
    It might be possible to use a wobble/rotary broach to do this but the only type i have seen leave a symetrical hole ie hexagon internal spline ect but the holders l can be self made but you would have to get the tool made as the the usual silver steel tool(hobyist aproach) would probably not fair to well with Titanium.
    Just a thought but if you are running batches of 100 you need to get tooled up and a wobble broach setup can be done in the lathe or mill.
    Regards
    Mike
  9. #19
    Hi Dean
    Regards
    Mike
    Cheers Mike I have seen this been done just but not seen or found any double D's clearly can be made to order, also not sure on what depth these allow. But is another option to consider and has you say if tooled up then this would make is post in doing it all myself and all on the mill.
    Very interesting https://www.youtube.com/watch?v=gUEcagEmmZo and http://www.polygonsolutions.com/rota...rotary-broach/You learn something new every day ..Clive
  1. wobble / wiggle on ballscrew double row angular contact bearing
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 14-12-2013, 08:35 PM
  2. Video of CNC machining a double sided part.
    By Shinobiwan in forum Woodworking Project Showcase
    Last Post: 17-03-2013, 11:23 AM
  3. Double gantry idea, What do you guys think?
    By craigrobbo in forum Gantry/Router Machines & Building
    Last Post: 25-12-2012, 10:01 PM
  4. Single or double??
    By Wobblybootie in forum General Discussion
    Last Post: 06-01-2011, 08:08 PM
  5. Double sided machining
    By CraftyGeek in forum General Discussion
    Last Post: 08-12-2009, 11:04 AM
