09-12-2014 #3
I use my friends router, my first build, which is not a mill, but is very precise/0.01mm and still continues to surprise me/
Ok, i get it. I haven't thought of that. So what you say is mill a bed, and then one by one fix them, flip them and mill them. Horizontally yes? Sounds better than lathe and simpler. or you mean the part to be vertical and do it at once? Wouldn't it vibrate like that?
As far as i understand you mean to make all this vertically, so i open the vice
PS:
The 6mm goes into triple bearing, so not that the diameter is so important as the center line of the piece, cause it must rotate dead on its center/2.5mm/ other wise when the bearings are encased, it will try to move them differently and friction will occure
Roundover finishing - what's causing this..?
By Wal in forum Woodwork DiscussionReplies: 4Last Post: 18-03-2014, 03:37 PM -
New Gantry Ideas
By Tomnewry in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 05-02-2014, 10:00 PM -
BUILD LOG: 5'x3' Ideas and build.
By Wal in forum DIY Router Build LogsReplies: 17Last Post: 29-12-2012, 02:03 AM -
Need some ideas
By jpcnc in forum Machine DiscussionReplies: 20Last Post: 29-01-2011, 07:56 PM -
Any ideas on the best use of this????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 01-08-2010, 11:41 AM
