01-02-2015 #7
It needs between 3V and 24V passing though it to work
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
FOR SALE: leewood 3 axis controller from an isel 3 axis cnc
By nobby in forum Items For SaleReplies: 1Last Post: 24-09-2014, 09:08 AM -
Fix engrave vertical gap or Upgrading laser cutter control card Leetro MPC6515 ?
By Paul Shroom in forum Machine DiscussionReplies: 3Last Post: 18-05-2014, 03:40 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM -
WANTED: Need electronics, anyone upgrading??
By fasteddy in forum Items WantedReplies: 2Last Post: 25-09-2009, 06:46 AM
