Thread: Chineese 6040 problems
Eddy, there is some confusion from Kendrick here - I have spoken to K on the telephone and he has a 400hz vfd and a 24k spindle. I do not think that he can control the spindle speed with his software (only from the vfd and he is quite happy with that), he is unable to stop/start the spindle and I think he should be able to do that if someone can advise him. I can't help because I use dedicated controllers on both of my machines (commercial system, not mac), but I am sure someone on here can point him in the right direction. G.
21-02-2015 #2
Starting/stopping the spindle is often done using a output which controls a 5V Relay who's contacts connect to the VFD run Signal.
Often the BOB will have Dedicated on board relay connected to output.
Reason for the Relay is that the VFD run signal will probably be 24V so can't be directly controlled using the 5v Output.
21-02-2015 #3
Have a look in here; http://www.mycncuk.com/forums/227-Ro...es-Controllers top two posts look promising.
picture of the guts; http://www.aliexpress.com/item/4-Axi...953030341.html
and this could be the vfd manual; https://drive.google.com/file/d/0B4P...kxJ/edit?pli=1Last edited by EddyCurrent; 21-02-2015 at 01:15 PM.
21-02-2015 #4
The second link gives me an idea as to what I should find when I finally take the to off the is that black box called a Bob.
the third link looks promising the control panel is identical,have not read it all yet.
kendrick
21-02-2015 #5
No the BOB is short for break out board. That second link showing the Guts isn't what you have because it shows a USB Motion control card and you had Parallel port based box. The BOB will look very similair to the USB card in the picture.
NOW BE WARNED.!! Messing around with BOB without knowing the pinout and numbers is sure fire way to KILL it.!!
BOB's and esp a cheap one that will undoubtly be inside this box are fickle creatures at best of times so don't mess unless your sure what your doing.
21-02-2015 #6
Got it widescreen
thanks
kendrick
22-02-2015 #7
There is a kind of problem I have, when I first got the Cnc going it was not that fast but liveable with, after calibration it now moves super slow fine for cutting but not from getting from a to b when not cutting. Surly if the original speed could be achieved to start with why can't it use it now, I tried travel speed on the mach3 screen with no luck I can slow it dow even more but not speed it up to its original speed. I can live with the speed if I have to but a faster travel speed between cuts would be nice.
the primary reason for buying the Cnc was for cutting carbon fiber sheet, I know that I need a diamond shaped cutting bit I got some from China but I think it would be better if I got them from America can anyone else suggest a place to get quality bits at not to expencive a price max cutting diameter 2mm also what rpm and cutting speed for diferent thicknesses of carbon.
to save the lungs I am going to cut the carbon in a water bath do you think building the bath deserves a thread of its ownas it is not a problem with the machine but a build project.
finally after seeing videos of wood being cut and when I cut a notch out of the leftovers from the base of the water bath I think enclosing the machine in a polycarbonate box would be a good idea a vacuum head with brushes is not always a good idea, a clear polycarbonate shield would be usful though.
kendrick
On going chinese 6040 problems
By amxen in forum Chinese MachinesReplies: 65Last Post: 03-06-2020, 08:46 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
my 6040 experience (yeah, and problems) so far
By jimbo_cnc in forum Machine DiscussionReplies: 52Last Post: 07-10-2014, 11:26 AM -
Durability of a 6040 ?
By jimbo_cnc in forum Machine DiscussionReplies: 10Last Post: 11-08-2014, 01:37 AM -
6040 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 01-10-2012, 07:18 PM
