Thanks Jazz thats very clear and as I expected, however few more questions if I may:
- What to do in case of using connectors for example like this one http://www.automationtechnologiesinc...h-connector-12 where drivers are connected to patch cable with this connector?
do I ground the patch cable only? the shield on the long cable to motor would be left as is in that case.
- With that cable in your photos how are able to distinguish the 3 black wires from each other??
thanks!
01-03-2015 #2
Same idea because the 4 pin connector is not used at the Drive end. To keep shield continuity the Connector will probably have a shield connection point. If not then create your own by soldering or trapping shield on the connector body.
The Black wires have numbers printed on them you just can't see them in pics. But for safety and piece of mind it's also a good idea to check continuity as you go along like neil says as it's very easy to get wire in wrong place, even with coloured wires your eyes go wonky when it starts looking like spagetti.!!Last edited by JAZZCNC; 01-03-2015 at 01:45 PM.
FOR SALE: 3 nema23 sanyo 3a 6.35 shaft 4 wire motors - 3 3a 24v 6560 drivers - 24v 15a psu £100
By nobby in forum Items For SaleReplies: 0Last Post: 22-06-2014, 01:59 PM -
VFD to motor cable wire size (Gauge)
By artman12us in forum Spindles & Drive MotorsReplies: 2Last Post: 24-04-2014, 07:11 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
30 gauge solid core insulated wire
By Wobblybootie in forum General DiscussionReplies: 8Last Post: 23-06-2010, 10:17 PM -
Motor controllers/drivers/wire ?!?
By Lee Roberts in forum Motor Drivers & ControllersReplies: 8Last Post: 24-08-2007, 08:46 PM
