Thread: BALLS!...The race type
04-03-2015 #2
Having worked with them for a few years in my day job my advise would be If you can afford the ceramic bearings then why not. Just be sure to get the accuracy and preload class correct. Contrary to common belief, they are as tough as the hardened steel ones.
Typically you will get the hybrid types on machines where the races are steel and the balls are silicon nitride or carbide. The balls actually condition the races somewhat and the whole system works smoother with less friction even at near dry conditions.
Best of luck.
ballnut - balls back in via the side cover and using less balls than original
By dsc in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 16-11-2013, 04:27 PM -
How to get the balls back in a ballnut?
By Shinobiwan in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 24-03-2013, 04:35 PM -
Balls, balls and balls
By Swarfing in forum Marketplace DiscussionReplies: 15Last Post: 21-03-2013, 08:45 PM -
X2 change balls crews or not?
By Oldie45 in forum Sieg Milling MachinesReplies: 7Last Post: 17-08-2011, 07:55 PM -
Lost my balls!!!
By danielbriggs in forum Lead Screws, Nuts & SupportsReplies: 26Last Post: 19-08-2010, 02:41 PM
