How many watts is the laser tube and what type of wood are you cutting?
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
25-03-2015 #2
Wood is a very variable material and difficult to define the power and speed required.
However, if the laser tube in the M700 is 50w then try to get a piece of 3mm acrylic which should be able to be cut at a speed of 8mm/sec and power of 65%
If this is not possible, then I suspect the laser tube may be low in power, or, the optics are not clean and aligned correctly.
All this is assuming the software machine parameters are set correctly.
I hope you are successful at getting it working.
31-03-2015 #3
Strangely I have the same issue. I've finally got mine working and now it won't cut through 6mm acrylic at full power (50w). Shows a slight shadow so i'm thinking its probably alignment or cleaning issues.... anyone any other ideas???
03-04-2015 #4
Put a touch of receipt paper over the last mirror and test fire the laser. It should be center of the hole. Shadowing usually means a cracked mirror(including the last one in the tube) or the beam is clipping on of the mirror mounts(usually the laser head).
The Following User Says Thank You to Isaac For This Useful Post:
laser cutter/engraver rebuild build log
By gavztheouch in forum Laser Machines & BuildingReplies: 37Last Post: 10-11-2015, 05:37 PM -
eBay: Laser cutter/engraver
By Bartell in forum Items On eBay UKReplies: 2Last Post: 18-07-2014, 01:30 PM -
New here and wanting to build a CNC laser cutter machine
By Gravatel in forum Laser Machines & BuildingReplies: 22Last Post: 13-02-2014, 05:10 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM
