    Wal's Avatar
    Quote Originally Posted by mordy View Post
    run MACH3 in a virtual machine (not emulation) using parallels on the MacBook Pro
    I do believe that Jazz has already answered this quite comprehensively, but really...
    DON'T DO IT.
    There are the straightforward ways of doing things, and there are ways that invite all sorts of ball-ache.
    Wal.
    having in mind an old PC , Dell 2-3ghz, 1-2gb ram together with the screen and Xp installed , at a bootsale is under 50euro , i don't see even why running a VM could pass through your mind. Ahh, yeah, i get, you are one of the Apple people
    DON'T DO IT.
    Wal.
    I hear ya Wal. But there is a couple questions i'd like to explore, expanding on the previous answer, I am sure if Jazz has decided he "has answered quite comprehensively" he will not reply or tell me so.
    No need to shout about it. I know it's frustrating with newbies, but I am sure you were one once etc.
    Well first I will answer you even if I think I've answered enough because i realise living upside down on other side of world must make the blood run to your head so there must be brain damage which makes learning harder.. .
    Now being serious. The ESS smooth stepper is ok and will work for you even with Macbook.
    Running Mach3 in emulation isn't the problem it's the parallel port driver that's the problem. But the fact you will be using ESS (or any external motion controller) removes this problem because it uses it's own software that runs inside of mach3 and the hardware generates the pulses.
    That said I still VERY STRONGLY advise you to get a stand alone PC just for the CNC machine.
  6. #5
    And here is me thinking its my Half British Half Spanish Background that has been hindering me all my life, now I see, it was all those negative G's from airforce flying exacerbated by the 'down under' affect that's done it.
    I'll go to trash and treasure this weekend for a PC. (bring the voltmeter) even though I will eventually be using the ethernet rather than PP. (thats the plan, but it is just a plan)
    Thanks guys for your help so far.
  7. #6
    Wal's Avatar
    I still consider myself very much a noob - yes, I've built a small vertical mill which is servicing my needs very well indeed, but it was only built thanks to the help and advice of the good people on here.
    At the best of times it's a delicate process getting things dialled in and 'just-so' - I'm thinking that the software set-up you're proposing will add an extra layer of quirky behaviour that could have you going round in circles... And your nice clean MacBook will be filthy within hours..!
    Good luck with it, whichever way you decide to go!
    Wal.
  8. #7
    Wal.
    Thanks Wal.
    Poor MacBook it has a hard life in my shed, you reckon I should give it a break....
  9. #8
    Wal's Avatar
    Exactly, pop a doily on it and use it as a tea tray. <...he types on his MacBook Air>
    Wal.
  10. #9
    Wal.
    Mmmmm to carry out my Tea and Crumpets to the shed. (that would be my british influence)
    Thanks Wal you made me laugh a bit.
  11. #10
    Excuse me we are British and it simply wouldn't be British to have Crumpet in the Shed.!! . . . We Do It round the Back of the Shed. .
  1. Corian and similar products
    By Fivetide in forum General Discussion
    Last Post: 20-10-2012, 03:36 PM
  2. Cutting bits nomenclature - help requested
    By DanielF in forum Tool & Tooling Technology
    Last Post: 12-05-2012, 04:53 PM
  3. Links directory
    By ptjw7uk in forum General Discussion
    Last Post: 19-02-2011, 11:09 AM
