http://uk.rs-online.com/web/p/multic...cable/6600460/ This is might not be heavy enough ..Clive
30-04-2015 #2
Does it need to be suitable for drag chain?
30-04-2015 #3
30-04-2015 #4
Not all stranded cables are good for drag chains.
I would go for this one: http://www.helukabel.de/en/en/produc...tKey=STD_49620
01-05-2015 #5
01-05-2015 #6
how much do you need? We have a lot of offcuts of cable that we used to use.
but if you need good quality encoder that is designed for cable chains, then it will not be cheap.
We sell 16 core flexible cable, but it will cost you £8 per meter.Visit Us: www.automationshop.co.uk
04-05-2015 #7
Thanks but for £8/m i will go with original Samsung cable, which is around 5€/m in eBay or automation shops.
I need only 1 off cut around 3m, or 1 piece 5m and 3 pieces 2 meters if i am just to solder ends to elongate.
But as i see it I will use the HDMI cable for the moment. the other day i won an auction at ebay for 50m HDMI cable 24AWG for 20 euro, so i could use it to rewire all encoders with one piece cable each.
WANTED: 75mm or longer Flexible Brush strip.
By JAZZCNC in forum Items WantedReplies: 14Last Post: 16-11-2016, 09:20 AM -
WANTED: 4 core CY cable... midlands
By kingcreaky in forum Items WantedReplies: 2Last Post: 27-12-2014, 11:41 PM -
What is meant by 4-core CY cable?
By MikeyC38 in forum General ElectronicsReplies: 31Last Post: 12-10-2014, 11:26 AM -
Flexible Stainless Steel pipe that holds its shape?
By Fivetide in forum Marketplace DiscussionReplies: 15Last Post: 14-02-2013, 07:35 PM -
Metal shielded cabling
By alanb in forum General ElectronicsReplies: 4Last Post: 07-02-2010, 11:07 PM
