  1. #13
    Thanks.A bit stuck at the moment. Have wired in the Y encoder but a bit of confusion about whats needed next. I know I need 0V and 10V Ref but a bit confusing as I also have an enable option.
    Connect the enable on drive to an output on IP-A and set the Enable 1-6 Output in Mach3 to port10 pin(which ever used). You can connect all drives to same pin to save outputs if you like.!
    This will enable the drives when Mach is Reset and disable when Mach isn't.
    If you want an extra layer of safety then run this signal thru your E-stop relay. So Enable can only happen if E-stop not pressed. This way the Axis won't be enabled even of Mach is reset( Which it shouldn't if E-stop is done correctly)
  1. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 08:17 AM
