10-09-2015 #2
10-09-2015 #3
Hmm, interesting
Just thought of another difference, the CandCNC MP3000 DTHC uses three parallel cables - one from the pc to the controller and then one to the motor drive BOB and another to the I/O BOB, these last two are new, shorter cables.
Might be worth swapping the old long cables back in???
10-09-2015 #4
Don't think cable length is the cause. Anyway I see only one BOB on the photo and presumed you use Mach3.
Actually did you test all drivers set to "active low"? As far as I understand you have Y and A coupled as master and slave. Wrong polarity might make them "rough" as they need to move in sync while the others may also need low trigger but do not show rough movement because they are single. ??Hmm.
10-09-2015 #5
The mp3000 has two BOB's one for motor control and one for inputs and outputs, yes i am running mach3
All drives were running active low on the test pc, Y and A are slaved in mach and each on their own output.
11-09-2015 #6
CandCNC advised me to up the pulse width to 5us and that seems to have sorted it out, all drives now running the same way.
The Following User Says Thank You to Davek0974 For This Useful Post:
11-09-2015 #7
New Build-12x6ft Plasma Table
By F1transportationserv in forum Plasma Table MachinesReplies: 23Last Post: 04-07-2015, 12:14 AM -
Plasma table build, first question....
By Davek0974 in forum Plasma Table MachinesReplies: 51Last Post: 01-08-2014, 03:11 PM -
4' x 4' plasma table build in Canada
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
BUILD LOG: Let The Fun Begain, New build on the Table.
By Bush Flyer in forum DIY Router Build LogsReplies: 63Last Post: 20-11-2013, 09:19 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM
