Thread: Easy Servo Drive?
15-09-2015 #22
I guess the parallel port was never really intended for time critical applications.
I ordered the ethernet easy stepper (ESS) from Amadeal last night and they already shipped it! I can't afford any down time on my machine for some weeks so I will have to try it out later on.
I also bought an 80V driver for the X axis that matches the ones on the Y axis. I'm sure it doesn't make much sense to run Y axis on 80V and X axis on 50V as I currently am.
How big a PSU do you guys usually run for Y and X axis? Currently my Y axis is powered from a 500watt toroid with 10,000uF smoothing caps (no SMPS here!). I wonder if it has enough headroom to power the X axis too, or if I need to get an additional PSU. A basic electricity meter shows my machine draws about 250watts for both Y and X together under normal use, but the meter will not show peaks (then again PSU caps should supply peak current draw).Last edited by Tenson; 15-09-2015 at 02:03 PM.
Build Log: Servo Drive and VFD with vector control
By Jonathan in forum Electronic Project BuildingReplies: 17Last Post: 05-04-2015, 07:58 PM -
eBay: SEM SERVO MOTOR SEM MT30 U4-48, LAMBDA psu,s, 160v servo drive
By dazza in forum Items On eBay UKReplies: 0Last Post: 29-01-2015, 08:55 AM -
FOR SALE: 160v dc servo drive
By dazza in forum Items For SaleReplies: 0Last Post: 27-01-2015, 03:16 PM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Servo drive problems
By Tomnewry in forum Motor Drivers & ControllersReplies: 15Last Post: 27-03-2013, 11:30 PM
