Would this fit the bill?
https://www.kickstarter.com/projects...kt/description
21-09-2015 #2
Fantastic - I love seeing things like this and spend a lot of my time browsing the various crowdfunding websites. Problem is that I need the machine within the next few weeks, as much as Id like to be in a position to purchase one of these and wait, its not ideal for me right now!
22-09-2015 #3
Have you evaluate the Chinese 3040 5 axis design that looks like a mill?
Just remember that you will need to pay shipping and VAT on top if bought on EBayhttps://emvioeng.com
22-09-2015 #4
Do you mean this one - http://www.ebay.co.uk/itm/5-Axis-CNC...c=1&rmvSB=true
I have been specifically told to avoid this machine by the guys on here. Shame really, it looked so promising! haha
23-09-2015 #5
Those machines can hardly cope with machining wax, let alone any form of metal.
To be honest, if you are looking at machining anything harder than aluminium, then you are best looking at a mill.
Cutting steel needs much more torque and lower spindle speeds and a much more rigid machine than a traditional router design.
you would be best to get a 3 axis CNC mill and add two rotary stages to give you 5 axis, but you also need to consider the cnc controller as well.
Or get a second hand 5 axis machining center.
23-09-2015 #6
Buy FS4MG LANG and add one of those china 4th/ 5th axis.
http://cnc-technik-mueller.de/fs4mg-...lgussmaschine/
This + usbcnc (Eding) + leadshine closed loop stepper 2nm (ebay) + gdk80-12-24Z/1.2-2.2 spindle
But be prepared that the end price is around ~6.5K euro without tax
Fusion 360 as CAM software (3+2axis) "free"
Also buy a haimer 3d probe , a bunch of 1/2/3 flute VHM mills for alu and a decent toolsetter + add limit switches to the machine + a decent vice (the Vertex VA4 fits nice on the bed)
Now you home the machine -> inset the haimer probe -> it auto measures length and does compensation (G49) -> zero the stock
Now run your code -> insert endimill -> auto measure length and G49 it (saves you so much time and makes your tolerances much better).
Having a spindle that has ATC is even better ... but those are quite pricey.
I have not done any steel yet , but I can't see why it is an issue (forgetting the spindle speed).
They Also Have the FS3MG which is "made" for steel. The base price is quite a bit higher but still doable for a small business.Last edited by DuffelBuffelWuffel; 23-09-2015 at 07:22 PM.
05-10-2015 #7
BUILD LOG: Steel Gantry Machine 1500x750x200
By toomast in forum DIY Router Build LogsReplies: 99Last Post: 02-03-2018, 06:27 PM -
polishing stainless steel machine
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 17-08-2014, 04:46 PM -
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
Milling Steel?
By Musht in forum Metalwork DiscussionReplies: 12Last Post: 02-12-2012, 08:00 PM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM
