I have just ordered these. http://www.ebay.co.uk/itm/141781789185
29-11-2015 #2
29-11-2015 #3
Are those NO or NC?
29-11-2015 #4
So those Prox switches that detect metal does that include aluminum which is non-ferrous?
Or is it ferrous metals only they are looking for . e.g. they contain iron.
Those prox switches your buying don't look to be shielded. Should prox switches be shielded or does it not matter so much?
I have just re-read your advice on the KK01 resistors. Thankyou.
Just to clarify are you certain that no resistors are needed going from the KK01 to the drivers, in the step, enable, dir wires?
I can't see why they would of put that diagram in showing different resistors, and I am certain that getting that wrong could be bad.
It's painting electronics by numbers at this end. Sorry for repeat question.
I'm getting my head round it slowly.
Manual : http://cnc4you.co.uk/resources/KK01.pdf
Martin
29-11-2015 #5
Yes, it could be bad if you get it wrong! But look carefully at the table of resistor values in the diagram. You'll see that for 5V, the required value is zero. That is, a resistor of zero ohms. In other words, a piece of wire! That diagram is slightly misleading and in reality it comes from the data sheet of the driver rather than the BOB. The KK01 BOB is fed from 5V and cannot put out anything higher, so the diagram is misleading and there is no situation where you might need those resistors anyway. However, the drives are designed to take a 5V input and if you use a different BOB running at a different voltage you might need them. Just like the inputs to the BOB, where you need resistors if you use a 24V limit switch system but not if you work at 5V.
29-11-2015 #6..Clive
29-11-2015 #7
They will sense Aluminium but you have to get very very close and they are erratic so NO is the answer. Sense to a bolt head or Metal plate etc.
Clive answerd that he does what I do.
They are completely separate and isolated things don't worry.
29-11-2015 #8
If you run your target bolt head axially on to the sensor, one day you will jog onto it and crush the coil in the head. Put your sensor at right angles to the motion of the axis, so the bolt passes by the sensor. My MD machine was designed with axially mounted sensors. Jeesh !
RobLast edited by cropwell; 29-11-2015 at 03:54 PM.
The Following User Says Thank You to cropwell For This Useful Post:
29-11-2015 #9
Rob common sense to me and can't believe MD or anyone would position any switch not to mention Prox switches so they could be crashed into.!
Another reason is the sensing repeatabilty is actually better when sliding over rather than approaching head on. Most Quality Prox switches data sheets will give specs on both types of approach.
29-11-2015 #10
OK Great. Thanks Jazz.
So hopefully that's the plan sorted now. Reckon I might get stuck along the way, but i will give it a go.
So am i right in saying I need NC ones. So that when it detects something it opens and breaks the circuit ?
I will have to ensure that the aluminium frame of the router won't cause false triggers then on the prox switches.
Does NPN or PNP matter for my purposes ?
Do these look like they will do the job?
http://www.ebay.co.uk/itm/1-5Pcs-Ind...U0u32s_xiK0nkw
Thanks again for all your help. Couldn't of done without it.
Martin
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
