Hey gents
Brilliant thank you very much for the tips. Unfortunately I don't have access to a lathe although the occasional eBay search has been done
. I thought I might be able to achieve a similar creation by glueing some washers together in a stack on a plate to keep it all true. I have seen that people also put taps into the drill press and do it this way that I thought may be worth a try.
17-12-2015 #2
17-12-2015 #3
Hey Neil
Yes just to keep it straight really and manually turning the drill. although press the button and you have your own indoor heli.
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
FOR SALE: SFU1605 Ballscrews and Nuts 950mm, 1150mm and 1500mm, SBR16 950 Rail, SBR20 1150 Rail
By Maccydu in forum Items For SaleReplies: 1Last Post: 12-12-2015, 09:55 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Straightness of steel/alumunium box section
By Jonathan in forum Linear & Rotary MotionReplies: 50Last Post: 17-09-2010, 07:53 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
