    jegg's Avatar
    Lives in Chelmsford, United Kingdom. Last Activity: 03-03-2016 Has been a member for 9-10 years. Has a total post count of 1.
    I have a 2008 EM 1325 CNC and I'm having problems with the machine
    wanting to go where it wants and putting cuts in the board where thiere not programmed
    but I think the DSP needs changing does anyone know if this is possible?
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by jegg View Post
    Hi jegg and welcome to the forum.
    You will need to give more specific details of what is happening. Pictures of the inside of the control box etc. In what circumstances does it happen. Give as much info as you can.
    Depends if your meaning changing for a new DSP or to another controller like Mach3.? . . I don't like so won't use DSP but I think they can be bought so direct replacement shouldn't be difficult.
    If your meaning to another Controller type, which is what I'd recommend, then you'll need Break out board and to match the DSP in performance terms an external motion control card.
    Your next question will most likely be how difficult.? Not very if your electricly minded but if not then leave it alone because it won't be simple as plug n play.
    Next will be how Much.? Can't accurately answer that because several types and manufacturers all with different prices but expect £200 + for decent setup.
  4. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  1. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  2. Spartan 1325-3 cnc machine
    By calibanman in forum Gantry/Router Machines & Building
    Last Post: 02-07-2015, 12:04 PM
  3. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
  4. MACH 2008
    By Lee Roberts in forum General Discussion
    Last Post: 05-10-2007, 09:48 AM
