Page 16 of 18 FirstFirst ... 61415161718 LastLast
  1. #151
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Just looking at this quickly - go to the top of this page - you'll see 'Thread Tools' which has a 'Printable' option that you can select. From the printable version you can print to a .pdf. You'll still need to do this for every page, though...
    Nice to see you on again Wal. Also there is an option on the printable version to show 40 posts on one page (at the top right hand side)
  2. #152
    Wal's Avatar
    Good call on the '40 posts' Clive. Yeah, I've been lurking a bit... I'm around one of the weekends in Feb (8th?) I'll give you a shout and maybe drop in for a cuppa!
    Wal.
  3. #153
    f1sy's Avatar
    Lives in Oxford, United Kingdom. Last Activity: 24-05-2018 Has been a member for 8-9 years. Has a total post count of 7.
    I'm new to the forum but want to build something similar to this (very similar) I have read the thread a few times and am in the process of re-drawing the design in NX as I am not familiar enough with Sketchup to be confident releasing parts from it for manufacture. Also I think if I redraw it I will have a better idea of exactly how it all works and whether it will still be suitable for my requirements.
    Could you please provide exact part numbers for the ball screws and linear rails you have used in this design. I have got the Hiwin catalogues but am unsure of the exact components that have been used. Once I know exactly what is used I can then start modelling these also.
    Really enjoy reading the thread and have learned a lot already.
    Thanks in advance for any help you can be.
    Thanks,
    Sy
  4. #154
    Quote Originally Posted by f1sy View Post
    You forgot to ask what he would do different if he was starting again
  5. Quote Originally Posted by Robin Hewitt View Post
    You can see that for yourself by looking at the next one!! Boyan's going to have built 6 or 8 machines by the time I've done one I recon!
  6. #156
    The main difference is that i would have done all from aluminum plate, cause i spend too much time cleaning, , aligning, welding, painting, etc. When you draw the line is not that much cheaper and aluminum is more beautiful to look at.
    Speaking especially about a machine made for sale , not for one for my self.
    Querido Silyavski, have you some detailed info, or some thread that point me to the right way about how to level with epoxy top and bottom of Y Gantry? i think that wil be a little hard to get it perfectly leveled :/
  8. #158
    Quote Originally Posted by samsagaz View Post
    Read from here if you want to see all the troubles and experiments #84. Or jump directly to #121 to #126 to see how to be done properly on any size machine. There is no escaping buying the West System epoxy with the slow hardener. If you read all you will see i tried other epoxies with poor result.
    impossible to get that brand in Argentina :/ btw, reading your posts now, thanks for the link!
    looks like some of your pics dont work anymore :( http://www.mycncuk.com/threads/6619-...7113#post67113
  10. #160
    Then you have to download the technical sheet of West System 105 resin and 209 hardener, understand all details and search for similar stuff there. Or buy from USA. I bought from UK, in Spain it was veeery expensive
  1. BUILD LOG: Steel frame cnc router design/build
  2. BUILD LOG: First steel diy CNC router build
  3. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  4. A Sturdy Steel Framed Machine Design
    By Boyan Silyavski in forum Machine Frames & Beds
    Last Post: 06-11-2013, 05:58 PM
  5. BUILD LOG: 7' X 4' Steel frame build
