    Quote Originally Posted by JW1977 View Post
    Can you recommend any products? If I remember correctly the distance between the centers of my ball screws is 684 mm at X.
    I was figuring twice that + a little for the pulleys and some kind of tension adjustment device at center.
    It will depend on how you setup the tensioning system and idlers. But with 20 teeth pulleys which is good size because gives nice balance of teeth engaged and pulley size which affects inertia of the screw and can have big affect on power requirements. Arranged something like whats in the picture then your belt length will be in the region of 1600mm.
    Yes, something like that.
    I liked the principle of this one...
    Yes that way works ok and I've used similar setups my self in past but ideally you want to reduce the amount of idlers to minimum. So if you have no restrictions to where motor goes etc then other way is slightly better. Less friction, less to go wrong.
    Yes, you’re right. One pulley is a better solution… But the symmetrical one looks nicer…
  5. The Following User Says Thank You to JW1977 For This Useful Post:
  6. #5
    Both look the same after you put cover over them to protect . .
  1. Drives without steppers
    By Wobblycogs in forum Gantry/Router Machines & Building
    Last Post: 27-03-2014, 01:07 PM
  2. Cheapest CNC steppers I've ever seen!
    By D.C. in forum Marketplace Discussion
    Last Post: 02-02-2013, 11:22 AM
  3. Different voltages on different steppers
    By Lovre in forum Motor Drivers & Controllers
    Last Post: 12-12-2012, 11:28 PM
  4. Has anyone used these steppers or drivers?
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 24-03-2011, 02:24 PM
  5. Emco 5PC steppers
    By Ian Hart in forum Stepper & Servo Motors
    Last Post: 26-02-2010, 02:47 PM
