    Chaz's Avatar
    Great, thanks.
    Things are simpler on my manual Bridgeport - just throw in a tool, set the speed to the chart and turn the hand wheels at a rate that keeps her happy :) Got a lot to learn - my reason for building a CNC partly.
    So i have a g-code file from SheetCam and it was programmed for say a 6mm roughing cut leaving an allowance for finish, do i need to make a second file for the finish cut or do you use the same cutter but just program a final cut for the finish pass??
    One job i have in mind has some 3mm holes in it, i would be looking at ramping in with a 2 or 2.5mm tool for them and then do the outside profile with a larger tool maybe - I am lacking knowledge of how you change tool and get back to exactly the right place OR do you use the tool dia offsets in Mach3
    As i said, lots to learn;)
    Get Fusion 360, watch lots of good utoob vids on how to CAD and then CAM in it. Sorted.
    I have that installed, trial period. I found it very complex TBH.
    For what i need to do, SheetCam should be ok, I am very familiar with that as I use it a lot for my CNC plasma table, but that has no tool sizes - just the torch and that never changes size :)
    Will be watching some videos though
  1. Q: Start Kress 1050 with Gecko540?
    By Trulsen in forum Kress Milling Motors
    Last Post: 01-10-2013, 04:50 PM
  2. eBay: Kress 1050 FME-1 Spindle
    By viz in forum Items On eBay UK
    Last Post: 21-08-2013, 04:04 PM
  3. eBay: Kress 1050 FME router
    By rbs in forum Items On eBay UK
    Last Post: 08-05-2012, 12:40 PM
  4. FOR SALE: 4 Axis CNC with Kress 1050 FME & Computer etc
    By miribilist in forum Items For Sale
    Last Post: 26-02-2012, 09:12 PM
  5. collets for a Kress 1050
    By groov in forum Kress Milling Motors
    Last Post: 20-08-2009, 11:54 PM
