    Cheers for that Jim... Just reading through formulas and working out pitches at the minute :) mind bending!
    Quite a good explanation here... http://rlab.org.uk/wiki/Project:Large_CNC_Router ....but it still twists my mind - although it'll soon seem like common sense and I'll wonder what I was ever confused about!
    Quote Originally Posted by dcrowder View Post
    That's very funny because that's my wiki page! :) I am a member of rLab (http://rlab.org.uk) and I use the wiki page to document projects and stuff and hopefully "inspire" me to maybe finish some of them!! Google really does get everywhere....
    Nah, if you are anything like I was (am?), you will file the information away somewhere "safe" and the next time you need the same info you will forget where you put it and ask the question here again! :)
    Cheers,
    Jim
  3. The Following User Says Thank You to cncJim For This Useful Post:
    A fine piece of work! It's really helped me get my head around what is going on.
    Once I had read through that and also had confidence in the units I was entering in the axis calibration, it enabled me make some progress today :)
    The machine is all zeroed, calibrated, motors smooth.. I went with 10x steps for the X & Y - and 4x steps for the Z as the motor would stop rotating at higher speed using 10x - my thinking behind this is that I get more torque the lower the steps....... Correct me if I'm wrong there though please!!!
    I've just strapped a marker pen on to the Z and managed to draw an alien face so I'm rather chuffed right now.
    On a lighter note... I also want to point out (this post being made shortly before the referendum) that we should be thanking the EU for getting us to use metric instead of imperial. I can't imagine how hard it is for our yankee chums working all this out in Inches
  5. #4
    Glad it helped Dave. I can't take the credit though, that info is all from the many many many posts on this forum.
    It can take some digging (the search functionality doesn't always make this easy) but often you will find what you need.
  6. #5
    Quote Originally Posted by cncJim View Post
    you can say that again!
  7. #6
    Yep, I have pretty much given up using the forum search. Much easier to use google to directly search the forum like this:-
    "site:mycncuk.com microstepping mach3"
    Works really well and is much faster! :)
  8. #7
    1am and I've already learned something new for the day :)
  9. #8
    No harder just decimal point is in different place.!!
    Well your sort of correct but like most things in CNC it's not that simple.!!
    Resonance is big factor in stepper performance and lower micro stepping often make the motors run in area that they get affected by resonance. This cripples the performance.
    Jim mentioned it briefly but playing with micro stepping can drasticly increase performance. Every machine resonates different so there's no one setting that suits all machines. ~However rule of Thumb is that higher MS runs smoother but at the cost of stress on the pulse engine. Basicly many more pulses are needed. So if your using the Parallel port some times running high MS can tax the parallel port which struggle to cope with supplying consistant train of pulses. This degrades the quality and frequency and all sorts of strange things can happen. Things from missed steps to poor performance or stalling motors.
    That's why External motion controllers are much prefered if running machines at higher feeds. like routers. Small machines like mills etc can get away with using PP and lower MS because they rarely run in Mid band or higher speeds which is where steppers/drives get affected most.
  1. daft question on LED indicators and high VDC
    By dsc in forum General Electronics
    Last Post: 15-10-2014, 09:29 PM
  2. RFQ: Daft Punk Build
    By FIREWIRE in forum Projects, Jobs & Requests
    Last Post: 19-04-2013, 02:34 AM
  3. I promise I will stop asking daft question soon. Ish.
    Last Post: 15-10-2012, 11:37 PM
  4. A daft question about vibration damping
    Last Post: 11-10-2012, 09:57 AM
  5. Unit Conversion Tool 5.1
    By Lee Roberts in forum Machine Discussion
    Last Post: 27-02-2008, 02:14 PM
