  1. #7
    How about this?
    I bought the UK one above and made a push-fit ball adapter.
    I used 01 Tool Steel for the sleeve, a 6mm Stainless Ball Bearing for the ball, a bit of spring wire I had laying around for the spring and spring retaining pin.
    The spring is soldered to the bearing, I used a big old fashioned flame heated 1lb copper soldering iron and Killed Spirits for flux. Cleaning the excess solder off with a file doesn't touch the bearing and a quick polish on a coarse wheel cleans off any residual surface solder.
    I've made the spring a little strong but it will do for now and the main bit is that it works rather well and I'm not scared of hitting the work with it ;-)
    - Nick
ID:	18334   Click image for larger version.
ID:	18333   Click image for larger version.
  1. Any ideas or thoughts on making a edge finder come touch off tool
    By suesi34e in forum Electronic Project Building
    Last Post: 01-01-2020, 06:28 AM
  2. "Hacking" and "Modding"
  3. 1/4" / 6mm edge finder?
    By jcb121 in forum Marketplace Discussion
    Last Post: 18-03-2013, 02:58 PM
  4. "Racks" VS "ball screw"
  5. Electronic edge finder: how do they work?
    By irving2008 in forum Probing, Digitizing & Scaning
    Last Post: 29-08-2009, 10:25 PM
