Page 2 of 2 FirstFirst 12
    Quote Originally Posted by Slixxor View Post
    The bed size is 1300x1000. I am happy to run whatever I need in order to be able to mill aluminium comfortably. I opted for the 34's due their torque at low rpm. Can anyone suggest a nema23 suitable for the application, they certainly are cheaper :)
    nema 34 is overkill and won't work as expected try these https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23 more than capable for that size of machine
    Thanks Clive S,
    you've saved me $420 AU. Does anyone else agree with Nema23 23HS45-3504S being the best choice for a steel gantry and Z axis?
    that will likely weigh over 30kg?
    Lives in Plymouth, United Kingdom. Last Activity: 5 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    I'm using these in a slightly larger machine, steel gantry probably weighs around 50kg, and I'm not expecting any problems. It's a very common setup. You do need to drive them with a suitable voltage - 60V or more.
    Agree with 23's .. ball screws = 10 mm is ok (5mm better axial load deflection needs looking at )
    I assume you are in Aust, so these links might be of assistance. Both are in Melb.
    http://www.homanndesigns.com/
    http://stores.ebay.com.au/CNC-AND-CU...=p4634.c0.m322
    CHECK THE SCREW LENGTH This guy normally lists travel length ..
    Paul
  5. #15
    Thanks @Paul3112, saved in favourites. :)
    This is the kit I ordered but had modified for my lengths: http://www.ebay.com.au/itm/331320314...%3AMEBIDX%3AIT
    This is the motor kit I wanted to buy: http://www.ebay.com.au/itm/171994192...84.m1436.l2649
    This is the motor kit I am considering now: http://www.ebay.com.au/itm/171937212...84.m1436.l2649
  6. #16
    Kits are hardly ever a good idea as they are never matched. You need motors with very low inductance and drives that can handle 68V volts to get the best out of them. Go for a toroidal type power supply rather than a switch mode type.
    Before you start spending hard earned cash it might be better to do some research as these parts can make all the difference between a good machine and a duff.
  7. #17
    Thanks Clive, I dont have an issue with switchmode PSU's. As a worst case i'll make a quick back EMF circuit and put some filtering caps across the bridge.
    You are dead right about the affect of inductance on supply voltage, especially at higher RPMs. So I have found a reasonably priced torquey Nema23 model
    http://www.ebay.com.au/itm/3PCS-3Nm-...EAAOSw37tV85jU
    inductance is 3.8mH - The lowest i've seen on ebay in that size.
    What is everyones thought on this motor?
  8. #18
    Not quite sure whether you mean you'll use a switch-mode supply or not. However, the linear supply is often better to drive steppers; the duty cycle of the load is relatively low, even though the peak demand can be high. With a SMPS, you need to rate it for max peak load to avoid it going into current-limiting where a linear supply can handle the peaks even if rated for average load. But then, you can buy cheap SMPS from China...
  9. #19
    My 1000x700 build uses Mema 23 425oz 3amp at around £20 each, and they plenty of torque and speed, forgot to change DOC other day set to 3mm 6mm 2 flute for MDF (cuts MDF 6mm 2 flute at 15mm DOC Regularly), so ended up slot cutting 5083 aluminium at 3mm DOC 6mm 2 flute 1000mmpm FR, stepper torque was not a problem and it cut without incident but was working harder than it would normally.
  1. WANTED: 2 x 20mm Fully Supported Round Rail
    By longy in forum Items Wanted
    Last Post: 30-03-2014, 09:21 PM
  2. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  3. Anybody used these linear bearings before?
    By pjl83 in forum Rails, Guideways & Bearings
    Last Post: 08-06-2010, 12:42 PM
  4. Supported linear rail question.
    By IN-WondeR in forum Rails, Guideways & Bearings
    Last Post: 05-02-2010, 12:25 PM
  5. 16mm supported rail how many linear bearings
    By progomez in forum Rails, Guideways & Bearings
    Last Post: 15-01-2009, 09:39 PM
