Page 1 of 6 123 ... LastLast
    After I set my z axis to zero in a g code run the Z axis moves below set zero.What am I missing?
    Sent from my SM-G361F using Tapatalk
    The first thing to eliminate is the code itself, if it has a G54....G59 the code is applying an offset which will override your zero.
    Best to at least post code to the point where Z drops below your zero,
    - Nick
    It dose it in a few codes I've tried to you have any code I can try
    In my CAM software I define the top surface of the work as work coordinates Z Zero. Any cuts down into the work are then in the -ve Z direction. So it goes below zero when cutting but that is normal. Is that what you mean?
    You can also define the bottom of the workpiece as zero in CAM and then set work Z zero at the bottom of the work (eg the spoil board). Then all cutting is +ve Z
    Can you write down each step you are taking as this might help understand your problem? Explain at which point it does something unexpected. Video and screenshots may help if it is difficult to describe
    lucan07's Avatar
    Lives in northampton, United Kingdom. Last Activity: 21 Hours Ago Has been a member for 9-10 years. Has a total post count of 257. Received thanks 24 times, giving thanks to others 6 times.
    With a plasma cutter I believe sheetcam is a popular product to use with Mach3 and looks simple to generate plasma code with
    There seem to be no g54 or g59 how do you set up the z
    What dose the red light at the z mean
    A video
    Somebody delet above sorry
    lucan07's Avatar
    Quote Originally Posted by whensparksfly View Post
    you should be able to edit and delete
  1. Replies: 9
    Last Post: 23-05-2015, 02:07 PM
  2. Replies: 9
    Last Post: 08-06-2012, 12:12 PM
  3. NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
  4. moves ok when using jog in mach3 but....
    By deannos in forum General Discussion
    Last Post: 28-12-2011, 09:40 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
