As Robin said, for plastic, use a HSS tool ground with large positive rake and lapped to a sharp edge.
To check the tool height quickly: gently clamp a 6" rule or similar strip of thin material between the work piece and the tool - It should be vertical if the height is correct. If the top of the rule leans away from the tool the tool is too high, if the top leans towards the tool the tool is too low.
and by the way
NEVER LEAVE THE CHUCK KEY IN THE CHUCK
NEVER LEAVE THE CHUCK KEY IN THE CHUCK NEVER LEAVE THE CHUCK KEY IN THE CHUCK
even on a mini-lathe ! it is a bad habit to get into.
[edit] You might be able mill a mm or two off the bottom of Kip's old tools to make them usable in your mini lathe, if they're not too high in the holder.Last edited by BillTodd; 03-09-2009 at 01:25 PM.
03-09-2009 #2
You might want to have a look at MIT lathe and workshop videos.
http://techtv.mit.edu/videos/144-machine-shop-8
04-09-2009 #3
04-09-2009 #4
Miniature Lathe for Pen Turning - Brushed or Brushless Motor?
By Nealieboyee in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 29-10-2012, 11:34 PM -
Mini Lathe Part
By fragger6662000 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 15-11-2011, 07:13 PM -
FOR SALE: Sieg C3 Mini Lathe
By Jonathan in forum Items For SaleReplies: 1Last Post: 07-05-2011, 06:19 PM -
A Mini Lathe
By irving2008 in forum Milling Machines, Builds & ConversionsReplies: 19Last Post: 03-05-2010, 04:11 PM -
WANTED: SIEG C3 Mini Lathe
By derekm in forum Items WantedReplies: 5Last Post: 07-04-2010, 08:35 PM
