Thread: Work Holding Tape/glue
Don't know of a UK supplier, I just buy mine from Germany
14-06-2016 #2
14-06-2016 #3
22-07-2016 #4
so following on from this threat I decided to do some R&D with different glues and ive found a winner.
http://www.screwfix.com/p/no-nonsens...ve-200ml/41795
I also purchased the cheapest 50mm wide masking tap from screwfix and it all worked a treat.
I used this method but with the glue from screwfix
just done the below, its pretty small at 100mm by 100mm but the gluing method worked 100% perfect and just popped right off once I was finished. I only used a tiny bit of glue so its going to last ages. it dried and was rock solid in about 30 seconds
next I want to try cutting letter out like this
22-07-2016 #5
Good Call!
I use Wickes Mitre Bond, an activated cyanoacrylate, and an aluminium tool plate when I'm machining and/or profiling small parts from gauge plate, stainless and titanium on the milling machine.
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
Alternative to tabs for work holding? Double-sided tap? 0.5mm thick, long tabs?
By mattnedgus in forum Woodwork DiscussionReplies: 6Last Post: 18-02-2016, 04:19 PM -
V fold Tape
By orangeart in forum General DiscussionReplies: 2Last Post: 11-02-2016, 07:16 AM -
Glue for Vacuum Press Veneer?
By Tenson in forum Woodwork DiscussionReplies: 16Last Post: 05-09-2014, 03:42 PM -
Workpiece hold down by glue
By Robin Hewitt in forum Machine DiscussionReplies: 2Last Post: 30-09-2010, 08:22 PM
