    Hello, can I use deionized water as a coolant for the 40w laser.
    I can only get distilled water if i order it in but some shops near by do deionized water for ironing and car cleaning etc.
    Would deionized water destroy my laser? cheers
    Distilled water is deionised water using heat. Normal deinoised water for batteries and such is virtually the same thing but made using reverse osmosis and thus cheaper.
    Use any deionised water you like but always put some radiator fluid in to avoid it growing algae in the tube. 5% will suffice
    https://emvioeng.com
  3. The Following User Says Thank You to komatias For This Useful Post:
    Great , just what i want to hear. Ordering in distilled water was getting expensive compared to deionized water. thanks
  5. #4
    Do you mean antifreeze when you say radiator fluid.I got a bottle of this stuff in the picture. would this stuff be ok.Click image for larger version.
  6. #5
    http://hpclaser.co.uk/index.php?main...products_id=79
    something like this would be better i suppose
  7. #6
    Quote Originally Posted by CNCPete View Post
    This is fine. I use cheap halfords type stuff. Change it every 6 months but should be good for a year or longer depending on use. Make sure you have a large quantity of water if you are running for a long time.
  1. Water cooling system tanks
    By d4cnc in forum Swarf & Chip Management
    Last Post: 06-01-2016, 08:55 AM
  2. Jcb water cooling adventure part two.
    By jcb121 in forum Metalwork Project Showcase
    Last Post: 04-07-2014, 07:46 PM
  3. Replies: 17
    Last Post: 18-09-2013, 06:32 AM
  4. water cooling options for spindle
    By routercnc in forum Tool & Tooling Technology
    Last Post: 12-02-2012, 11:22 PM
  5. i7 Water cooling system
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 01-01-2012, 06:27 PM
