05-07-2016 #1https://emvioeng.com
05-07-2016 #2
Oh ye Sorry forgot your official title is Old B''####d. . Lol
Well I've not seen any, well any that are affordable anyway. Likes of your Siemans etc may well but they are very expensive. Also think you mean +/-10v not 0-10v different animal.
Yes course can if got spare axis but John asked if IP-A could output Step/dir as well which it can't.Last edited by JAZZCNC; 05-07-2016 at 04:25 PM.
05-07-2016 #3
With a KFlop & Kanalog it's possible to use both +/-10V and step/dir, however to use the step/dir outputs you have to sacrifice Kanalog encoder inputs.
05-07-2016 #4
06-07-2016 #5
Mix and match.
There are 8 encoder channels (actually 16 differential inputs on the Kanalog - they're not solely for encoder inputs), which at KFlop level means 16 inputs, but those 16 inputs are actually general purpose IOs which also provide the Step/Dir outputs.
4 of the encoder channels go through a separate RJ45 (Ethernet style connector) cable to the Kanalog, with the other 4 being in amongst the main 26pin ribbon cable with all the other signals. If you only need 4 encoders, you can simply make up your own cable to take 4 sets of Step/Dir signals from the RJ45 connector on the KFlop. Otherwise you have to start splitting cables depending on how many encoders and Step/Dir signals you need.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
06-07-2016 #6
Brushless DC Motor - Mach3 Compatible - Opinions?
By smartbusa in forum Brushless Spindles & MotorsReplies: 3Last Post: 23-12-2015, 11:42 AM -
servo motors questions
By paulus.v in forum Stepper & Servo MotorsReplies: 4Last Post: 27-07-2015, 10:31 AM -
help with servo motors Please.
By ramsbury in forum Stepper & Servo MotorsReplies: 10Last Post: 18-02-2014, 04:59 PM -
Bridgeport boss stepper motors
By speedhound in forum Stepper & Servo MotorsReplies: 1Last Post: 12-12-2010, 08:54 PM
. . . Anyway 4th axis wasn't mentioned when I suggetsed that route.
