Thread: Hi newbie looking for advice
Hi and welcome to the forum!!
Well there's plenty of info on here for inspiring your build so you've come to a good place!!I'm looking to build a CNC router
Not ideal as will need machining to get a decent flatness but depending on what you want to cut (what do you want to cut?) will probably be ok.The bed will be made from 40mmx40mm T section steel with slotted idlers running on the outer edges (for now
) for the gantry, and similar for the y axis gantry
Doubt you'll get 100x500 out of the dimensions you state, it's amazing how much room the gantry and Z axis take up. My machine is 1300x850 and I get 970mm x 500mm (just!) but that's because of the design I went for!bed size is 1200mm x 600mm (so i can get a full 1000mm x 500mm cutting are)
Generally motor kits are not matched very well, the motors tend to be high inductance and the PSU underpowered resulting in a slow machine. You're far better off buying separate items which the lads on here can recommend.....but only really worth doing that when you have a design up (which we'll happily critique) and say what you realistically want to cut.I've seen on the net a motor kit, NEMA 23 motors (1.8 step 178.5 oz inch)
DM542A driver
350w 36v 9.7A switched PSU
now will this set up be ok the motors will be driving a belt two to one reduction gear then timing belt for the x and y axis
and a screw for the z axis (200mm)
thanks mark
04-08-2016 #2
04-08-2016 #3
No problems Mark, get a design drawn up for everyone to look at (it's surprising the little things you don't think about that others who've done it before know about) and take it from there. Don't buy anything until you've got your design finalised, especially the electronics, as things can change quite alot...
P.s. unfortunately you need speed to cut wood....unless you've a slow spindle.Last edited by njhussey; 04-08-2016 at 11:25 PM.
06-08-2016 #4
Hi thanks for the info,
what is the ideal speed for the x and y axis if cutting MDF/Wood/Plastic/light metal?
As to software has anyone any recomendations for a MAC
Newbie hoping for acrylic advice
By Red_Stafford in forum New Member IntroductionsReplies: 12Last Post: 25-06-2016, 07:11 PM -
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
NEW MEMBER: CNC Newbie
By GaryWilliams in forum New Member IntroductionsReplies: 0Last Post: 22-04-2015, 12:41 PM -
Which controller and motors? Newbie advice please
By Nealieboyee in forum Motor Drivers & ControllersReplies: 14Last Post: 16-10-2012, 02:56 PM -
newbie need advice on cnc machine to purchase? routoutcnc machines any good?
By wyndham in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 27-05-2011, 08:54 PM
