Thread: Engraving/machining acrylic
thanks for all the info
I have a denford micro router, which is enclosed. I did wonder if things in general were getting hot yesterday, it was a hot day and once I closed the door of the router there is no air movement inside.
how small can you get single flute cutters? I want to engrave so didn't want to go any bigger than 1mm really
19-08-2016 #2
Do you have any dust extractor? In my opinion that is VERY important.
The smallest bit I am using is a 0.5mm but it is a dual flute. Feed rate is EXTREMELY critical, run it just a tiny bit faster and it snaps. But... if you are engraving for LED signs then V-bits are better unless you need to engrave large letters or remove a lot of material, because those are more rigid. Never the less, if you run it too fast or too deep you will snap off the tip, especially the tiny 10degree 0.1mm are very sensitive.
19-08-2016 #3
19-08-2016 #4
Please note that I still don't have my high speed spindle installed om my machine, and my current spindle is maxing at 9000RPM, so perhaps if you spin your V-bits fast enough you can increase feed rate as well. Anyway, 22k RPM and 300mm/min is not a good combo. With 22kRPM I would try at least 6-900mm/min using a 30degree 0.3mm V-bit. You have to watch out for corners, the machine may drop the feed rate speed but the spindle will continue spinning at 22k RPM, so melting can happen when rounding corners and then continue on the straight part or the mass of the melted plastic will snap the tip, whichever comes first.
I think it is easier to master milling and engraving at lower RPM first before speeding up things. Once you know you can do it you at low speeds you can start increasing the speeds and understand better what is going on if something goes wrong.
On a side note... I'd start with a brand new and sharp V-bit because if you use an already used one, especially if used on aluminum, then it might not be as pointy and sharp as needed for plastic. A defective or damaged cutter may cause problems (melting, bad edges, uneven surfaces and so on) or may give you good results which are not valid for a new and sharp one. I think it is best to use good tools, so buy a bunch of those and keep a stock of them. You will need more than one before you are confident enough...
Good luck. Milling and engraving acrylics is fun.
The Following User Says Thank You to A_Camera For This Useful Post:
16-09-2016 #5
15-10-2016 #6
Thanks for the advice got speeds and feeds perfect
17-10-2016 #7
17-10-2016 #8
03-11-2016 #9
19-08-2016 #10
Acrylic Cutting Help
By Tenson in forum Machine DiscussionReplies: 26Last Post: 08-11-2016, 08:15 PM -
My Engraving and Micro-Machining Solution
By magicniner in forum Machine DiscussionReplies: 7Last Post: 16-04-2016, 07:19 PM -
Acrylic or mdf I can cnc
By rainboweyes in forum Opportunities Available & SoughtReplies: 0Last Post: 19-02-2013, 02:09 AM -
Which end mill to level my acrylic bed?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 18Last Post: 03-02-2012, 02:57 PM -
Acrylic suppliers
By Web Goblin in forum General DiscussionReplies: 2Last Post: 24-10-2011, 09:11 PM
