Thread: Kopal Milling Clamps
We used Kopal clamps on a Hmc at work to hold 350x350x25mm plates for machining and they gave great clamping force but I would recommend making some steel bushes that you can knock on the knurled part of the screw to increase the strength of the Allen socket because they are prone to breakage if you over torque the screw so the coller stopes it ripping apart and becoming useless. They will be a pain to get off if you want to service the clamp but it's doable.
22-08-2016 #2
I've milled the hold-down bolt hole on two of mine out to a slot to take M10 custom bolts but it's a common misconception that the hold down bolts need high torque, they don't.
Kopal clamp hold down screws should be hand tight and not swung on, they only need to be tight enough to stop the clamp easily moving out of position before any clamping force is applied, the tool provided has the right dimensions to stop the uninformed swinging on the screw and applying excessive torque ;-)
The whole point of the design is that applying the clamp uses the hold down bolt as the pivot point of a lever with the work contact and the back end of the clamp as the pressure points.
If you break the screws you're not understanding the correct usage of the clamps :D
23-08-2016 #3
I fully understand how the Kopal clamps work and worked very close with Kopal along with a few work colleagues 19 years ago when we found that although the clamps where good on material with a clean edge they where pretty crap when it came to a flame cut edge or rough edge.
The problem we found was that the foot of the clamp wasn't in full contact with the edge of the plates we where using because they where flame cut so after having a few plates come flying off our HMC (one littereley taking the enclosed doors off the runner and bending the frame) we had talks with Kopal to look in to the problem. After we looked at the job and found what was happening and Kopals rep having seen what was happening the answer we got and only solution was to dog them down as much as possible until all the clamp was in contact with the edge of the plate which worked apart from blowing the heads of the screws out which is where we had to fit collets to the screw head. In all they are pretty good clamps but you have to torque them up more on anything than a good clean edge especially on a HMC.
23-08-2016 #4
It's common in industry to misuse and abuse equipment that is used outside it's design parameters but to describe that as a fault of the equipment rather than operator error is unfair on the product.
The correct solution to your problem would have been custom feet for the clamp noses which incorporated spherical contact surfaces to allow free alignment of a lower section with 3 distinct high points allowing clean 3 point contact on uneven surfaces, the rep sounds like he had no engineering background or problem solving capabilities beyond "big spanners" and when all you have is a hammer, every problem looks like a nail ;-)Last edited by magicniner; 23-08-2016 at 09:03 AM.
Lenzkes Tooling Clamps Qty2 - CNC Milling/Drilling
By mekanik in forum Workshop & EquipmentReplies: 2Last Post: 02-02-2015, 06:47 PM -
MOD 1 rack clamps
By charlieuk in forum Marketplace DiscussionReplies: 3Last Post: 31-01-2014, 09:07 PM -
Hold down clamps, what do you use?
By Web Goblin in forum Machine DiscussionReplies: 16Last Post: 14-04-2012, 11:45 PM -
Clamps
By p1lts in forum General DiscussionReplies: 3Last Post: 27-10-2011, 06:55 PM -
FOR SALE: Pneumatic Clamps
By compfranon in forum Items For SaleReplies: 5Last Post: 07-04-2010, 07:33 PM
