Thread: Advice on converting my VMC
26-09-2016 #2
Yeah, i know Chaz.
But my plan is not necessarily finding a solution as cheap as possible. I will spend the money necessary(within limits) converting it to a good accurate VMC.
However i was hoping to find parts I`m able to handle without me studying programming for a couple of years before i get it up and running.
Hope i don`t sound impatiant though :-)
26-09-2016 #3
26-09-2016 #4
The offline controller is simpler than the combo Windows-Mach3/4-motion control plugin-motion control. What programming? The first part of the manual covers manual programming of simple milling jobs i think that you mistakenly took for programming..
Once you set up your machine in controller menu
stick usb and hit probe, then play and you are done.
The mach 3/4 is the same as above, plus install Windows, plugin, macros, custom screens, etc.
All this talk about the offline controllers lately comes as search continues for simpler and more reliable than the windows combinations. These have existed from the time machine exists, now for first time they are cheaper than the windows solutions, which to begin with, were born out of necessity, cause a Siemens controller would set you up even today 10k
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
26-09-2016 #5
Hmm.. Okay Boyan,
I think i seriously need to sit down and take a closer look at the manual on this offline controller...
26-09-2016 #6
Must be something to this GSK 990 controller, because i just noticed Weiss Machinery are using them on some of their mills..
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Advice Needed, Converting a Boxford VMC 190
By Marv2097 in forum Boxford Vertical MillsReplies: 17Last Post: 19-12-2016, 05:53 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM -
Converting Cardboard to DXF
By Yow Ling in forum General DiscussionReplies: 12Last Post: 15-11-2010, 10:18 AM
