    So your assuming it can square the gantry individually or you are doing it.? . . .. You do know what they say about assumption.!!!
    If you are using 3 axis controller how are you running your machine which as 4 motors.? Are you using the servo drive slave option, meaning the slave servo drive mirrors the master. If not then surely your not connecting two drives to one Motor output.?
    Surely i am connecting 2 servo motors to one output without any problem. Reality is different that what we think is good or no good. Works perfectly. And if works perfectly at my speeds, for the normal DIY machine will be a winner
    The reality is that over time the tiny difference in timing issues will show up and with no way of squaring the gantry indepedantly, other than running into hard stops, the machine will slowly twist it's self up. Not good arrangment and not something I'd do or encorage.
    The problem and concern I have with these controllers is that they are not much more than DSP controllers which are fitted to many chinese machines.
    It's well known that these are trouble and I've helped countless people who have bought chinese machines replace DSP's after little just 6mnths because they have failed or start acting strange.
    When they start giving trouble there is very little can be done and they are throw away.!!!
    I never call or praise any hardware untill I've fully test my self so I'm not calling them or saying rubbish. But I will be trying one these for my self and after Thrashing it for several months then I'll see if it's Winner.!
    Yep my DSP lasted under a year, warranty, yeah right. Now running CS-Labs thanks to Dean.
  1. Comparing motion controllers...
    By JW1977 in forum Control Hardware & Systems
    Last Post: 17-02-2016, 02:36 PM
  2. Wiring Steppers to controllers
    By liamo1991 in forum Motor Drivers & Controllers
    Last Post: 05-09-2013, 01:58 AM
  3. PCI Motion Controllers
    By IanS1 in forum Motor Drivers & Controllers
    Last Post: 16-05-2013, 12:13 AM
  4. Difference between controllers and Cad/Cam programming???
    By 0625272 in forum Computer Software
    Last Post: 23-06-2011, 08:40 PM
  5. Programmable logic controllers
    By cncezee in forum Motor Drivers & Controllers
    Last Post: 15-11-2010, 08:44 PM
