    Has anyone come across a supplier of diamond impregnated brazing rods local to Europe ?
    I can get them from the US but wondering if anyone knew of a more local reliable supplier?
    Ralph Waldo Emerson
    Quote Originally Posted by Fivetide View Post
    Sounds like you may want to approach people that deal with the oil field or mining. (Cutting and Wear springs to mind) In all my time working with diamond, this is the first I am hearing of impregnated rods, would have thought the brazing temps would cause the diamond to graphatise... learn something every day.
    Have you contacted Johnson Matthey? They supplied me with some very rare rods a few years ago.
    http://www.matthey.com/about_us/prod.../metal-joining
    https://emvioeng.com
    Quote Originally Posted by komatias View Post
    I think they where designed for large concrete / stone cutting tools.
    I have had some from here years ago , well I say I got them , actually a got one from someone who had bought them from the site.
    But then I kicked myself because I remembered he had changed to a 2 part diamond epoxy which worked nearly as well at a lot lower cost.
    Thanks for the link though :)
    Ralph Waldo Emerson
    Can't help but you got me intrigued. . . What you welding.?
    For a try at making some of these :) I have a couple that where in a shed clearance (somewhere).. on eBay. And I PM'd the seller and he said his dad probably got them from the US site. But I have seen people use 2 part epoxy mixed with diamond powder for the size of spheres I'm attempting.
    I'm intrigued at the method they use for these LINK
    Ralph Waldo Emerson
    My first reaction to the video was..."Like f*** is that diamond impregnated". Cherry red colour on steel is in excess of 700C. Diamond turns to graphite at 600 odd.
    Has the chappy found some way of protecting the diamond I wonder? Will look for his patent.
    This appears to be data from reputable sources -
    http://www.colorado.edu/physics/phys...62_Diamond.pdf
    This suggests that diamond is OK to 800C - which might explain why diamond can be embedded in brass/bronze in a variety of applications and is commercially supplied in brazing rods.
    - Nick
    I have a friend who is a glassblower. He has a couple of lathes with diamond impregnated brass wheels and I often wondered how they were made. So the answer is casting, but with careful temperature control.
    Which begs the question - How do you true up a diamond grinding wheel ?
    Rob
    That's an excellent question, I have a diamond impregnated bronze grinding wheel which became a little rough in places after many years service, my solution was to swap it out for it's twin while I tried to find a solution, which I haven't yet found ;-)
    - Nick
    - Nick
    Theory is fine , but its like trying to fine hens teeth to get rough to polish grades , hence why I'm experimenting with epoxy . But for anything above a 5" sphere I doubt epoxy will be useful.
    Never seen an article on truing the wheels but have seen people say if used correct they can last 10-15 years. At £150 a pop for a big one I'd want them to last a bit to lol :)
    These guys produce the finished brazed cups in all sorts of grades and sizes
    Big scale sphere making.. Highland Park grinding cups
    Ralph Waldo Emerson
  1. Is there a specific setting for using a diamond drag tool for engraving?
    By petesos in forum Tool & Tooling Technology
    Last Post: 14-03-2014, 12:22 AM
