  1. #6
    I do not see where it is the complexity. My g-code is a list of points defined by XYZ. I need to look at the the XY coord. of every line and compare with my shape. If the point is inside the shape keep the line, if it is outside delete it. That simple.
    To get an idea of what I'm doing, I have the shapes already cutout and I'm applying a surface texture on them. I need to eliminate the extra movement, cutting out air, around the shape.
    Which leaves you with a set of moves which don't join up and aren't linked ;-)
  1. A little bit of G code help please!
    By njhussey in forum Programmers Corner
    Last Post: 16-11-2015, 03:36 PM
  2. Anyone got some 2.5D G-code please ?
    By dudz in forum Programmers Corner
    Last Post: 22-06-2013, 11:21 PM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  4. G Code help
    By moose007 in forum Programmers Corner
    Last Post: 22-05-2009, 11:39 AM
