Thread: DIY mill...
I hope to build a cnc'd mill soon, think i'm going to use ali and start from scratch. i'v been working on a design in cad but i have now desided to use ali not mdf so its a remodel now. One that will keep the costs down to.
03-07-2008 #2
The main issue with a mill for metalworking is rigidity otherwise you wont be able to take any reasonable sort of cut. Which is why I was interested in Kip's ally casting and the potential move to cast iron. His view is ally is too springy for this sort of work, at least for headstocks/quill supports but again it all depends on the design. I'm not convinced a flying gantry design would be rigid enough so I'm considering basing my design around a modified pillar drill...
I just picked this 36" drill with a cast iron foot/head and 9" sq table up of ebay for £15...
I know it doesnt look much now, but I think it will serve as a basis once I've done work on the bearings and sorted out a way to preload them. Then maybe shorten the pillar and modify the tableLast edited by Lee Roberts; 03-07-2008 at 08:53 PM. Reason: Changed Image Link to a local one, now loaded into our gallery !
03-07-2008 #3
I was thinking about doing somthing with this one:
Cost me 40 notes or 50 from Aldi, always find good deals in there !
03-07-2008 #4
I have one of those, cost me £20 on sale at B&Q a couple of years back... mine is the Performance Pro version but many places brand the same machine. I think its a bit flimsy for a mill myself, but depends on what you plan to do. The quill may need some serious work as it won't take much radial load on the tiny bearings. They'll need boring out and fitting with something more substantial I think. Mine has acquired lots of axial play after trying to drill 3 x 6mm holes in a chuck backplate :(
Bought my air compressor from Aldi, special offer £100 for the 2.5HP compressor, 30m hose, and about 9 or so air tools - the same stuff (again a branding exercise) is over £200 at MachineMartLast edited by irving2008; 03-07-2008 at 09:32 PM.
15-07-2008 #5
Things have moved on in the last week or so.. I did my back in picking some paper of the floor by my desk :( so no hard work on the machines and a couple of days off work at home.
Got a bit carried away on fleabay (you know how it is! :) ) and now have enough material for a 300mm X axis and a 200mm Y axis (rails, linear bearings, leadscrew) plus 4 steppers, a 500VA transformer and a 22000uF smoothing capacitor. Stepper driver chip samples are on the way as are power transistors and a few other parts...
Haven't quite worked out what I am going to build exactly but something that will mill PCBs and light aluminium work. All the calcs I have done suggest I could take a .15mm cut with a 10mm endmill in 6061-T6 ali with the stuff I have.
This will need a 50W spindle motor at 3000rpm. I'd want this to be as lightweight as possible and looking at motors that could do the job I was dismayed by their weight (typically 2 - 3kg). Then I was reading up about coolant and how mist cooling is the 'next big thing' and I was musing on how I could use my air compressor to provide the pressurisation using a modified airbrush head when an idea dawned.... why not use the air pressure to drive the milling spindle?
So, has anyone done this and if not, why not?
15-07-2008 #6
Because when Edison was criticised because his proposed DC mains supply would require a power station on every city block, he replied that the problem with AC was that it wouldn't run a motor.
Tesla responded by designing and incredible AC motor which is constant speed and brill for running milling machines.
Air is rather the opposite.
But you already know that, you are a one :D
19-07-2008 #7
To me building a cnc machine is like commiting suicide ...it just cant be done in half measures ..you either succeed or you dont. We've all tried to out think the existing technology ... you may be able to build something resembling a cnc with this drill ..but believe me ... after a week you going to be dismantling it to improve it with another idea ... this will continue for the next year .... 2000 notes and 1000 hours later ...you will be buying what you should have bought in the first place!
How do i know this --- been there --- thats is basically how we all started and hind sight can be a b****.
The Following User Says Thank You to amen23 For This Useful Post:
24-07-2008 #8
eBay got to me again.... picked up a brand new Dewalt D28885 500W 1.7kg die grinder as the basis for my milling spindle for £40, bit cheaper than the £100 asking price for a 500W Kress. There are a couple of places on the Net doing spares for the Dewalt and they list the spindle bearings as type/size 608VV so should be possible to upgrade them later if need be...
Still havent decided if this is going to be a fixed or moving gantry machine... I'm tending towards fixed gantry, moving table in X, moving spindle in Y & Z
23-05-2018 #9
Ha! Words of wisdom amen23! I built an aluminum extrusion machine and it works really well on plywood and acrylic and could certainly do some engraving, but I've started down the path to milling 6061 aluminum and I can do it, but not well. So, I thought, heck I'll just do some stiffening here and there and... flush... $$$... swirl... Anyway, I'm contemplating how to upgrade or keep this machine for wood and build another much smaller X/Y table type out of steel for milling. I can't really decide the way to go and my budget is very limited. Or maybe I sacrifice cutting area and use the parts from the existing machine to make the mill. Hmmmmfffff! Anyway, I'd love some input from y'all who have been down this path. I love CNC and making stuff, but I'm growing a bit weary of making stuff for my CNC.
If any of you would care to see my video saga on youtube, please take a peek and offer all the jabs and sneers you can muster. I can take it!
https://youtu.be/2QTZa2Ge9A0
Cheers!
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
