    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Weeks Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Not absolutely sure. These specifically say "iron sensing" or somesuch. Because I don't have the original listing for mine, I can't say what they are. Proximity switches are sometimes iron only, sometimes anything metallic (although with reduced sensitivity, as I understand it). Mine certainly trigger on aluminium. Of course, if your trigger component is iron or steel, then that's not important.
    Ive ordered 3 of them to test and see. They should be fine.
    Would you consider using Hall Effect sensors? No moving parts extremely accurate and will outlast mechanical switches. Take a look at these, they run on 5 Volts but I can modify to use higher voltage if needed. They operate in the same manner as a NO switch. However a NC can also be created and will not be expensive.
    https://www.tindie.com/products/Kard...ll_prod_search
    Quote Originally Posted by Kardacian View Post
    Great but 5v and not shielded = Problems
    The voltage problem can be solved easily, what voltage do you need to support. I run these without shielding and have had no issues. What would be an ideal shielding for your environment?
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    That's actually a bit of a generalisation, as it depends on exactly how you're powering things. I keep meaning to do a post on the why and how the problem can be mitigated to a certain extent.
    Regardless, IMO limit switches should always be fail safe I.e. NC, as you want to minimise the risk of a wiring fault causing the switch detection to fail.
    Plus, magnetic switches on something that could potentially be machining steel?
    biggest problem for me is the delivery charge !
    I see Hall effect switches mentioned more in US sites than UK. I'm not sure why you would use these rather than the Chinese-sourced proximity switches, unless you are in an environment where there is a lot of metal around and powerful magnet operation is desirable to avoid false triggering. For example, the proximity switches run natively on 24V. Is it really that there is a strong "not from China" feeling in the US rather than any pure technical reason? Just curious - I've a box of proximity switches in the workshop that I am using, so I've already made my design decision
    No Brainer to me Chaz.? . . . .The IP-A gives abilty to Home To Index so use it because will be superior to most SW and very repeatable.
    Also means don't need expensive switches for there repeatabilty/reliabilty. Any decent Mechanical SW will work because all you doing is triggering the point Servo searches for the Index pulse.
    Chaz's Avatar
    Thanks. Ill do some testing on the weekend. Ive not used the Index feature before, so will give it a shot.
    NO switches are not recommended as limit switch. I would never use them in a mill, maybe a 3D printer, but otherwise your switches look nice.
  1. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  2. 24v Limit/Home switches. How to..?
    By Wal in forum General Electronics
    Last Post: 17-11-2013, 05:52 PM
  3. Limit Switches
    By Leadhead in forum General Electronics
    Last Post: 16-10-2013, 10:41 AM
  4. Limit Switches with LED's
    Last Post: 02-01-2013, 03:08 PM
  5. Limit Switches
    Last Post: 27-06-2008, 02:21 AM
