Thread: Delrin drive nut (lee)
10x2 trap.....humm no i think the only one i'v got is 1/2" 10x2 in ACME. I can send you some delrin and you could grab a tap from ebay ?
if you are looking for couplers http://www.fish4parts.co.uk/Mechanic...F+SWQ%29.1852/
13-10-2009 #3
14-10-2009 #4
put a 4" length of trap rod in a drill chuck or lathe. Spin it up and apply a file to the last inch to taper it to the thread depth. Lock the chuck or hold rod in vice) and grind 3 'slots' at 120deg for 3" using a thin cutting disc (or file it if you feel up to it). lastly file the untapered end to a square.
Good enough for delrin. For a tigher finish lightly file the overall thread by about 0.05 - 0.1mm
I did it and it works... for nylon or acetal a few times... but wont do brass without hardening...
Delrin Lead nuts.
By Kammo1 in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 27-01-2016, 08:36 PM -
coloured delrin/acetal uk suppliers?
By dazza in forum Marketplace DiscussionReplies: 5Last Post: 26-05-2014, 12:35 PM -
Tapping Delrin for M10 threaded rod - doable?
By HankMcSpank in forum Machine DiscussionReplies: 7Last Post: 02-02-2013, 12:31 AM -
Delrin & Nylon S & F please
By craigrobbo in forum Machine DiscussionReplies: 2Last Post: 21-07-2012, 12:19 PM
