Thread: Where to get Mild Steel Plate?
30-12-2016 #2
A couple of 10mm plates welded as per Nick's recommendation and use 30/40mm square section on the edges for mounting your bearings or rails.Joining the plate is done by machining a pattern of holes in one of the plates you intend to join clean both matting faces and clamp them together then weld the inside the holes.
Regards
Mike
30-12-2016 #3You think that's too expensive? You're not a Model Engineer are you? :D
30-12-2016 #4
30-12-2016 #5
30-12-2016 #6
31-12-2016 #7
31-12-2016 #8
I'd go with steel if could work with it. However I'd only use it if could do it correctly which means will need heat treating and stress reliefing then grinding in critical places.
If you can't do this then you may find Ground tooling plate will be more accurate as it's already been heat treated and ground flat.
Plug welding will allow thinner plate to be used but all the above still applies and will require more work because all that heat will warp and put stresses into the whole assembly. If those are not released carefully then they will release eventually which will make for bad day when you do realise.!!Last edited by JAZZCNC; 31-12-2016 at 10:00 AM.
31-12-2016 #9
31-12-2016 #10
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
