Thread: Hi, I'm working on Cheap CNC
03-01-2017 #7
Just from what I've researched so far.
As i'm not an engineer or electrician technical answer you wont get from me.
I've just seen a LOT of DIY builds with reasonable accuracy.
When i see parts i see things that i've seen it in or used often far from the field that i'm researching.
Example would be when i looked at my mates WP site and had to learn the tinyest amount about mild steel.
With this i know that for £20 i can get 6m of equal angle mild steel at 3 or 4mm thickness.
This is made straight and is strong combined with V Groove bearing with a 2.5mm Drop (groove) should work as the roller bed worked in the car garage i once worked in.
Belt or Chain above Ball n Screw so i've been told, so i'm going with it for now.
I have 3 steppers controlled with Gcode and a universal gcode streamer.
Software Easel.com
Simple Pi or Ardunio Set up
Motor Drivers Power supply with plenty of Ampage.
Z drive not working on cnc plasma
By whensparksfly in forum Machine DiscussionReplies: 15Last Post: 10-05-2016, 02:16 PM -
Z drive not working
By whensparksfly in forum General ElectronicsReplies: 3Last Post: 14-04-2016, 09:14 PM -
Huanyung FVD PD002 not working
By eurikain in forum General ElectronicsReplies: 7Last Post: 28-02-2016, 03:27 PM -
x&z not working
By cncjohn in forum Linear & Rotary MotionReplies: 5Last Post: 18-08-2013, 12:58 PM -
EXPERIENCE: Working with JAZZCNC
By m.marino in forum Trading Experience & FeedbackReplies: 0Last Post: 02-10-2012, 11:47 AM
