    Your aim should be to achieve higher acceleration, than speed.
    This is the vital fact, I have found the negative side of this equation - low accel/high speed and what it does with Mach3 is give terrible contour following because of the constant velocity engine Mach uses. Its not just a little bad, it's the difference between turning out scrap and turning out parts.
    I have retuned with lower speed as higher acceleration was too jerky on my old Bridgeport conversion and its all working nicely now.
    Exactly Dave. Like all things in life Balance is the Key. Good machine is tuned with nice balance of speed and Acceleration.
    Getting wrong either way will have negative affect on machines performance in different areas of work type.
    For instance your case of high feed but with low accelration caused corner rounding. This was on relatively small parts with tight radius on small machine. On larger machine like router with larger parts say doors or shaped work tops etc with no or large radius sections then high feeds with Lower Accel will be ideal.
    Different strokes for different folks, Or machines in this case.!
    This is why Mach3 and some other Control software will let have you have different profiles which can be used to have machine tuned or setup differently to optimise the type of work your doing.
  1. WANTED: 150mm dia x 15mm wall Ali pipe
    By r0bsk1 in forum Items Wanted
    Last Post: 12-06-2014, 04:19 PM
  2. Melbourne Andy CNC 1220x810 working area
    By AndyGuid in forum Gantry/Router Machines & Building
    Last Post: 17-04-2014, 11:41 AM
  3. WANTED: Profile rails, 600mm and 900mm
    By Jonathan in forum Items Wanted
    Last Post: 16-08-2011, 09:18 AM
  4. Stick with Ali profile or venture into plate?
    By ecat in forum Metalwork Discussion
    Last Post: 22-08-2010, 09:00 PM
  5. BUILD LOG: Newbie First Build 3000mm x 1500mm
    By psiron in forum DIY Router Build Logs
    Last Post: 16-07-2010, 11:02 AM
