Thread: Parallel issues
29-01-2017 #8
My preference would be from Cslabs but not cheap depending on if you need slaved motors or not. However the UC300ETH would be my second choice provided it's connected to good breakout board that can provide 24V I/O.
When you say Mach is setup do you mean it's just been installed or you have set it up with all the correct pin numbers etc.
Just installing mach3 won't make the mach work. To work you need to tell mach3 where to look for incoming signals and where to send out going signals. To do this you'll need some info about how the machine is wired. This is known as the I/O system (input/Output) and if set wrong machine won't do anything.
If you don't know which pins are connected to what and can't get the info then you'll need to take very detailed pics and post so we can work out what hardware you have and whats going to where.
SEM DC Motor Issues
By Chaz in forum General ElectronicsReplies: 11Last Post: 21-05-2019, 10:10 AM -
Engraving issues
By D-man in forum Machine DiscussionReplies: 50Last Post: 29-02-2016, 10:01 AM -
50w laser - PSU issues?
By calida in forum Laser Machines & BuildingReplies: 1Last Post: 09-02-2016, 04:25 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
Page layout issues...
By irving2008 in forum General DiscussionReplies: 3Last Post: 09-08-2012, 08:10 PM
