Page 3 of 5 FirstFirst 12345 LastLast
  1. #21
    No, do not over tighten a toothed belt, it does not reduce BL and will overload the motor bearings. A properly tightened belt should have a small amount of give in it - you should not tighten it so you can play music on it :)
  2. #22
    Hi Dave,
    Cheers for that. Are you running a belt drive? Do you find you need to run backlash compensation on Mach3 with it?
    Lloyd
  3. #23
    I run toothed belt on both my mills, the bigger one has a heavy table and servo drives, if the belt is tightened just right there is no backlash to compensate for at all. The belt can move slightly but when that movement is converted to rotation and then reduced by the screw pitch, the actual distance linear is microscopic.
    I have tried backlash comp and i would not recommend it to anyone - always get the system mechanically sound and unless you are working to nuclear industry standards, just learn to live with the tiny backlash we have - there will ALWAYS be backlash or the system would not move, its just a matter of knowing how much.
  4. #24
    yep, couldn't agree more, do it right, do it once etc. I just wasn't sure whether switching from a direct drive to a belt drive inevitably introduced a hint more backlash regardless of how perfectly you tune the belt tension. Always faster/cheaper to learn from others mistakes etc. Should have the belt drive put together over the next few days so will be able to test backlash on all the axis.
    As you say we're not working to nuclear standards. I'm generally machining car parts on the mills, and the tolerances don't need to be that high. Its just I'm tired of using the Bridgeport like an oversized etch a sketch to try to make curved parts!
  5. #25
    Quote Originally Posted by Lloyd Barnes View Post
    I thought you were converting an AMAT25LV ?
    My Bridgeport CNC conversion was the best thing i ever did, it makes it a much more useful machine. The backlash i do have comes mainly from the screw thrust bearings - in the end i bought new units here and it helped massively, not cheap though. The next is screw nut slop - I just fitted a standard Bridgeport conversion screw set from the USA, its good but not excellent. I have less than 0.1mm backlash in both axes and i don't think thats too bad for an old girl :)
  6. #26
    Sorry not being clear am I. I have a series 1 Bridgeport but have bought the AMAT to convert to CNC. Sadly my Bridgeport, even though its a 1981 model is a bit worn. I can't adjust the gibs to acceptable play for a CNC machine without the ways tightening at the outer ends. Also I really wanted something I could enclose, the Bridgeport fills the shop with chips, and I'd didn't want to add to it by getting the coolant working too. I'll certainly keep it for general use where the part is not complex or for sizing stock for the AMAT etc.
    I read a load online and the general impression I got was converting a series 1 wasn't the best way to go, sounds like you disagree although perhaps you have a later model? I could certainly live with 0.1mm with the parts I make, not bad at all for a Series 1. I guess the bits were pretty pricey though?
  7. #27
    Ok, got it, makes sense now.
    I think you did the right thing, my BP can fling the chips a good 8' away but its only me so who cares :)
    I was strongly advised NOT to convert the BP and that advice was right. The advise was to sell it and get an old CNC VMC etc and retrofit the electrics - this would have been ideal BUT i could not physically fit anything but a BP in my shop - not even a proper CNC BP. I also do not have the power capacity for the big spindle motors on CNC stuff.
    Now i have used it a few times, I REALLY want a proper CNC mill with an auto tool changer. ;)
    Total cost was silly money but once you dive in you cant back out.
  8. #28
    Well, its about ready to go. I've taken the advice and setup the Z Axis with a 2:1 belt drive (very annoyingly I ordered the wrong belt length so just waiting now for the right one to come). Most of the rest of it is complete so once the belt is here its time to take a few trial cuts and see where it is. Y Axis NEMA23 with spindly legs is now mercifully covered up, cover plate for the X Axis next. Hopefully starting to cut some trial parts this weekend.
    /p
    Appreciate all the advice so far
Name:	Belt drive.jpg
ID:	20991Click image for larger version.
ID:	20992Click image for larger version.
Name:	Mill Closeup.jpg
  9. #29
  10. #30
    Well chaps, she runs like a good un! Many thanks for the advice. The Z NEMA34 motor didn't work with 48V and direct drive as you suspected, was losing steps. Switched it out to a 2:1 belt drive and all sorted.
    P
    Got Mach3 licenced today and ran a quick test part. Few screw ups here and there, didn't get the CAM quite right (Fusion 360) so the pocket bottoms didn't clean up, and like an idiot I managed to run the spindle in reverse for the first part of the chamfer op so that's a bit messy in parts, but that's just me being an idiot and easily fixed next time.
    P
    The machine itself I'm generally pleased with. It ran the part in around 40 minutes, and with fresh end mills that are a little sharper I'm pretty sure I can be a bit more aggressive if I needed to be. Dimensionally it seems to be cutting to around 0.1 to 0.075mm accuracy which I'm hoping I can improve by tweaking the jam nuts on the ballscrews to take out any backlash etc. What sort of accuracy do you think its practical to get on a small machine like this? 0.1mm would be fine for many of my parts I'll be making, some however I'd need a little better, for example where I'm after a sliding or press fit between two parts. I didn't put a lot of time into this part, it was more to get myself going on the basics so I'm sure with time I can improve.
    P
    Doubtless I'll have more dumb questions as I get the mill dialled in. For now though I'm planning on getting my tool library setup and sorted out in Fusion and get some parts through to get more comfortable with the CAM in particular. I'm still at the stage with Fusion CAM where I'm not 100% sure what I'm doing, particularly selecting the geometry to get it to do what I'm after but I'm sure it will get easier. Once again, thanks for the advice and encouragement. Much appreciated.
    P
ID:	21082Click image for larger version.
  1. Looking into converting my Mill to CNC
    By T0rnado69 in forum Emco Milling Machines
    Last Post: 14-02-2019, 12:46 AM
  2. Hello everyone need help converting a emco f1
    By Ecu-master in forum Emco Milling Machines
    Last Post: 30-03-2014, 08:42 PM
  3. Hi help converting emco f1
    By Ecu-master in forum Milling Machines, Builds & Conversions
    Last Post: 30-03-2014, 12:24 PM
  4. converting pdf to cam?
    By motoxy in forum Computer Software
    Last Post: 28-02-2014, 08:11 AM
  5. Converting sketchup to dxf
    By motoxy in forum Sketchup
    Last Post: 08-07-2012, 12:04 PM
