Thread: Converting an AMAT25LV
15-02-2017 #25
I thought you were converting an AMAT25LV ?
My Bridgeport CNC conversion was the best thing i ever did, it makes it a much more useful machine. The backlash i do have comes mainly from the screw thrust bearings - in the end i bought new units here and it helped massively, not cheap though. The next is screw nut slop - I just fitted a standard Bridgeport conversion screw set from the USA, its good but not excellent. I have less than 0.1mm backlash in both axes and i don't think thats too bad for an old girl :)
Looking into converting my Mill to CNC
By T0rnado69 in forum Emco Milling MachinesReplies: 16Last Post: 14-02-2019, 12:46 AM -
Hello everyone need help converting a emco f1
By Ecu-master in forum Emco Milling MachinesReplies: 3Last Post: 30-03-2014, 08:42 PM -
Hi help converting emco f1
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-03-2014, 12:24 PM -
converting pdf to cam?
By motoxy in forum Computer SoftwareReplies: 7Last Post: 28-02-2014, 08:11 AM -
Converting sketchup to dxf
By motoxy in forum SketchupReplies: 3Last Post: 08-07-2012, 12:04 PM
