    I think you just need to bend them further, to not spring back. You are probably not applying enough stress to go past the material's elastic limit.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    This.
    If you don't bend past the elastic limit, then they will just spring back, regardless of how long you leave the clamp on. Position of support blocks, and pressure application point depends on the bend. How much pressure is very much trial and error. Apply pressure, release pressure, check to see how much things spring back, then repeat with more pressure if needed.
  1. Centec 2 ballscrews
    By jonnydeen in forum Lead Screws, Nuts & Supports
    Last Post: 11-07-2023, 09:53 AM
  2. machining ballscrews
    By T0rnado69 in forum Lead Screws, Nuts & Supports
    Last Post: 13-04-2014, 11:39 PM
  3. machined ballscrews
    By wilfy in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2012, 05:42 PM
  4. Two ballscrews on both X and Y axis?
    By Jonathan in forum Gantry/Router Machines & Building
    Last Post: 02-02-2012, 01:55 AM
  5. supports for ballscrews
    By leadinglights in forum Lead Screws, Nuts & Supports
    Last Post: 27-04-2010, 12:31 PM
