Thread: 3 Axis CNC router
Only comment (if you have a chance to make any small mods at this stage) is to add a few more sets of terminal contacts for the output, all wired in parallel. This allows you to run separate power feeds to each stepper driver, rather wiring them daisy-chain fashion, and it's easier than trying to stick three big wires in the same terminal. Not sure if it really make a difference in our class of machine but it is generally considered good practice not to share high-power connections between devices, and it's a lot easier if you have multiple terminals available. Might be able to put multiple spade terminals on each of your contacts, though?
27-04-2017 #2
Thanks Neale, The terminals are overkill in terms of size and will take two cables each but as I've shown on the circuit diagram the plan is to take one feed from the terminals on the power supply to some din terminal blocks with a jumper bar to provide as many as I need...
27-04-2017 #3
Sounds fine. My PSU was originally bought from Zapp, although I have now changed the transformer in it, but it came with three pairs of output terminals already. Then I fitted it in a control box with four stepper drivers...
Must confess that I didn't actually put a wiring diagram together for mine, just some sketches to work out roughly what was needed. Then I set to work with a pile of cable reels, big box of ferrules and crimping tool, and quite a lot of black coffee. Don't try this one at home
Still, it does seem to work OK.
27-04-2017 #4
27-04-2017 #5
It's great when a plan comes together! Well done. All downhill from here...
27-04-2017 #6
28-04-2017 #7
Moving along nicely, very professional work!
30-04-2017 #8
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
3-Axis CNC Router - For Helices.
By Dalmango in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 08-02-2014, 07:27 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
