Page 2 of 2 FirstFirst 12
  1. Quote Originally Posted by Nickhofen View Post
    Hey thanks,I'll check it tonight after kids go to bed!
    if a 2:1 ratio why not a 1620 or 1610 if you wants better precision...
    Quote Originally Posted by pierantoine View Post
    That is another question for my potfolio I guess.
    Design of the x axis, I prefer to build it tapered and to use bolts ,with minimum welding, since it is one man job and better to handle, plus I want to avoid metal stress.
    Please feel to coment the design.X axis is made from 900x90x90x4mm steel structural sections.
    At front and back of the steel tubes I will place two steel plates 5mm to stiffness the structure ,also the two plates ,left and right, are going to be 5 -7 mom.
  1. First cnc build drive advice needed
    By threedee in forum Gantry/Router Machines & Building
    Last Post: 25-05-2016, 11:12 PM
  2. Build log. Design advice needed.
    By eurikain in forum Gantry/Router Machines & Building
    Last Post: 25-06-2015, 06:53 PM
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
  5. new mashine build advice needed
    By Finrod in forum Milling Machines, Builds & Conversions
    Last Post: 14-10-2008, 11:05 PM
