Thread: Thor, or should that be Zeus?
21-06-2017 #351
Bad luck Chaz
However I do seem to remember posting this about a week ago (post #283)
"However my personal preference on big powerful machines is to have the home switches inside the boundries set by the limit switches, and have the limit switches trigger powering off of the drives. Also to have the limit switches within the boundries of mechanical stops that limit travel before ball screws over travel."
The Following User Says Thank You to AndrewMawson For This Useful Post:
21-06-2017 #352http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
21-06-2017 #353
The Following User Says Thank You to Chaz For This Useful Post:
21-06-2017 #354
I think the main point is to have a physical limit to save the ball screws if there is a runaway - preferably with a hard neoprene or other suitable plastic buffer.
As for the latched relay then yes that's the easy way to do it, but it needs to be a fast acting relay.
24-06-2017 #355
Suppose this means it works.
Speeds and Feeds
24000 rpm - 6mm endmill
Cutting Rate 4000mm/min
Lead / Ramp at 1440 mm/min
This was run at 80% speed. Overall happy with the cut considering there is no finish pass.
DOC is 5mm, WOC is 1.2mm
Still got more to do, but happy with the initial results.
24-06-2017 #356
Excellent - congratulations !
BTW do you still want those Compac PC's ?
24-06-2017 #357
24-06-2017 #358
I haven't felt any disturbance in the force yet, I think you need to up the ante.
Milling cutters start to perform around 3/4" diameter and up, anything less than that is squidgy
24-06-2017 #359
24-06-2017 #360
Will do some more cutting tomorrow with 10mm endmill.
