Thread: Thor, or should that be Zeus?
03-07-2017 #381
03-07-2017 #382
A few have used these and they prove more than up to the job: http://www.ebay.co.uk/itm/371128026468, you dont need to go mad trying to cool these spindles down, they are quite efficient and shouldn't really get hot.
The Following User Says Thank You to Lee Roberts For This Useful Post:
03-07-2017 #383
03-07-2017 #384
Simple bypass from output to input - just a tap that can be opened gradually and you can set the pressure exactly as you want it. This was standard practice on the main Grundfos 3 kW pumps that circulated water in my Launderettes when I had them - simple gate valve and in that case a pressure gauge. High enough to fill a washing machine PDQ, but not high enough to bust the flexible hoses !
The Following User Says Thank You to AndrewMawson For This Useful Post:
04-07-2017 #385
I would add a 2nd pump to circulate through the spindle then hook the chiller to a thermostat like this
A pond style water pump will work fine I have a box of 20 of them I can send you one for free if you want and will use less electricity than the pump in the chiller.
With a reasonable size res of 20l's the chiller will only need to run a few minutes in an hour and I bet that water pump in the chiller uses quite a bit of juice.Last edited by Desertboy; 04-07-2017 at 08:28 AM.
04-07-2017 #386
06-07-2017 #387
What size pipe do people use? 6mm OD?
I managed to get a lot more powerful pump, pushes a good amount of water but when I connect up my plumbing, it struggles to flow. I have turned an adaptor to go from 1/2 to 1/4 inch (roughly) but the hole might be too restrictive.
Should I move up to 8mm piping?
The Following User Says Thank You to Chaz For This Useful Post:
06-07-2017 #388
8mm ordered anyways to check. I'm not sure how free flowing the water should be through the spindle, I went as far as removing the pipes and I get a slow flow, so I dont think its that.
06-07-2017 #389..Clive
06-07-2017 #390
