hello, the picture gantry/axis
about 40 inches
will buy three 40 inches long...
two for x one about the same size for y
a tiddler for z
do I link them with a belt or drive both x axissss
	07-07-2017 #2
I wouldn't drive anything from one side personally no matter what the machine is. Out of interest have you seen it done somewhere?
For plasma cutting forces are not there and as long as bearings under gantry have a fair spacing I don't see that it would rack in that sense (bind up)
But inertia forces are there. So rapid changes of direction on the gantry would start to give a bit of lag on the non driven side which means slight out of position cut. Question is whether this error would be large compared to kerf - someone who has used plasma more recently than me may be able to answer that one.
I would slave both sides or drive both sides direct.
	07-07-2017 #3
	07-07-2017 #4
	09-07-2017 #5
There have been many single sided drive plasma machines in the past but these were industrial machines and very well built with servo drives via gearboxes to rack and pinion drive on rail tracks. I think the widest machine I worked on would have been between 3 and 4 metres wide. Some had single heads and some with two. Twin drive machines are better and can move faster but then again cost more.
	09-07-2017 #6
Yes, it really just depends on how rigid the machine is.
We have a Morbidelli router with a cantilevered gantry, that's only attached at 1 side. It has no trouble cutting through 30mm particle board in one pass at 25m/minGerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
Double side machine a small part
By timtom1 in forum Woodwork DiscussionReplies: 0Last Post: 12-03-2015, 07:30 PM -
Drilling/tapping in ends/side of aluminium plate
By matt-b2 in forum Metalwork DiscussionReplies: 8Last Post: 13-01-2015, 01:31 PM -
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
Preventing racking?
By cncbobuk in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 26-08-2013, 08:03 PM -
Help understanding the software side of cnc routing.
By don_jarr in forum CAD & CAM SoftwareReplies: 5Last Post: 23-06-2011, 01:13 PM
